I just bought a 93 ATX and have just run the codes on it.
129 (R) No MAP or Mass Air Flow sensor change during "goose" test - MAP MAF
167 (R) No Throttle Position sensor change in "goose" test (must get at least 25% rotation) - TPS
225 (R) Knock sensor not tested (ignore if not pinging) - KS
332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
411 (R) Idle speed system not controlling idle properly (generally idle too high) - ISC
632 (R) E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
no clue what these mean really
Any help is appreciated
