codes 41 and 91
DavidT
TN
I thought I heard some chattering/ticking from the s/c'd 91. I put it in neutral, got out, and inspected the engine bay. I was goosing it at the throttle linkage, I heard NOTHING. Get back in the car, and I still hear it. It sings with the rpms. Uh oh, CEL is trying to tell me something. Now the idle is pulsating, and I see black soot on the ground below the tail pipes.
I perform the ce test. KOEO: 41 and 91 (initially, I get a 1, and then a 5... what does this mean?)
2. Is the noise a typical "clutch chatter" noise? I have never heard it before though...
3.Or is the noise I hear related to the lean codes? btw, KOEO... is 41 and 91 lean... or is that KOER only?
The symptoms that show up with the codes are: pulsating idle, black soot, noise.
Seems like ,iirc, one other time I was fooling with it at idle (goosing the throttle and letting it idle for 5 minutes or so) I got a 41 code. I cleared it and it never came back. But this time I get BOTH banks runnning "lean"...
any suggestions?
AREA 91
PA SHO SHOP
Area 91
Had the same problem on mt Mocha, thought it was an air intake leak, turned out to be the O2's after all!
