code p0430 repair
mclark
mississippi
What to look for to fix this code p0430, car runs fine, no loss of power or performance it seems to run better, gas mileage is good . I can clear the code and CE light stays off for about 200 plus miles then comes back on . Changed down stream o2 sensor with no fix, is it time for catalytic replacement, any ideas. 2010 w/109000 miles.
Since the code is only complaining about the effectiveness of the cat, the engine should run normally and have no loss of power.
If there is an oxy sensor problem in this scenario, it is far more likely to be the front sensor not switching at the proper point.
Are there any other codes being set? If not, I would replace the front oxy sensor on that bank.
toms89
That is the downstream sensor (after the cat) on bank 2 (Front bank) just to confirm. The gen 4 Taurus sho use wideband sensor upstream so have doubts that would be the issue. Unless you get code for it of course.
Ta2dResqr
Central Ohio
Did you change 1 sensor or both? Stock cats?
mclark
mississippi
No other codes only p0430, I've had it cleared three times and the same one code returns,
webbrook
ma
there are utube vidoes about using spark plug non foulers to space out the o2 sensor, it works as i have done this
webbrook
ma
there are utube videos about using spark plug non foulers to space out the o2 sensor, it works as i have done this.
mclark
mississippi
Update on code p0430 fix, after replacing both o2 sensors cel still lit up, started searching for Ford cat replacement, got lucky on ebay, seller had purchased exact Ford replacement cat for his vehicle come to find out that he did not need the part, he asked $525, I got it for $350, long story short, had cat replaced and no cel since, Thanks again
shoster207
