code confusion
zblackbeast
SHOtarded
Omaha, NE
So, the SHO when I let the clutch out idles really low like it'll stall then recover or just stall. And on the way back from the BBQ whenever wed hit a rest stop and id restart it its idle REALLY rough for a minute or two then go away. Never threw a cel or anything but I figured id run the codes anyway. I quickly last night ran a KOEO, keeping the thought of a bad MAF or IAC in the back of my mind, and got these..:omgsho:
552
157
519
542
115
452
Im going to rerun all the codes tonight as well as do a KOER test to see if I can pull more.. I understand the maf one and fuel pump one (iirc it trips that code if the car ever stalls) but wtf is the AIRB sensor? o_O thanks all for any other ideas
115 - ect out of self test range - usually a bad sensor, but could be wiring issue
157 - mafs below min voltage - usually bad mafs but could be wiring
452 - no vss input - usually bad vss, or wiring is melted
519 - psps circuit open - wiring issue usually
542 - fuel pump secondary circuit failure - usually fine to ignore
552 - does not show up on my list
good luck, hope that helps
