wespiece
- Joined
- Sep 13, 2016
- Messages
- 41
- Reaction score
- 2
I have a buggy that has an 89 SHO 3.o swapped into it and I am trying to clear the trouble codes one by one. The first code I would like to fix is the Purge Canister Valve Code 85. I know that one of the two wires in the connector is + positive and the other is the - ground signal from the ECM.My question is what would I need to put between these two wires, short of the actual solenoid, that would trick the ECM into thinking that the valve is present?
I am thinking of possibly patching in a 1k resistor and an LED. Would this be enough draw to clear the ECM? if not, any other suggestions?
Thank in advance for any help here!
