Code 528
Ferendon
Fort Worth, TX
Voltage to pin 10... A/C is off... What's the best cure. Running rich and overheating, replaced ECT sensor (single wire unit), and pulled superchip. I think I've gotten all the air out of the cooling system, but when I was adding coolant to the resevoir, I hearad a LOUD sucking noise, like the t-stat POPPED open. I mean, it was a real Pam and Tommy kinda noise... Car was running at the time, and was warmed up to slightly above normal operating temp. "RM" area... normal for me is "MA"
projectSHO89
SHOless In St L
Tip #1: If you have a code, search for it and my user name. I've covered many of them, including this one.
Tip #2: Keep continuing problems or follow-on issues in the original thread instead of starting a new one. It makes it easier to follow sequences of events.
Steve
