Code 528 and 542
Stracey R
Its been about a week since I had last driven my sho. So I decided to check codes after driving around, it drives fine and all. I have two codes:
528 System shows voltage at pin 10(is A/C on?). It wasn't on.
542 Fuel pump open, bad ground or always on.
Is my fuel pump on its way out? It sounded fine when I did the eec test.
Anyone had these codes before? This is the only codes that had showed up for over a year.
Thanks
Rob94
Northbridge MA
If the climate control is in any position other than off, you will get the code 528. As far as 542...have you stalled the car recently?
Stracey R
I guess I can disregard the 528, come to think about it, I did check the temp outside using the eatc.
For the 542, my sho cranked a bit longer than usual, could that be it? I never stall an mtx sho :) .
khanartist
oldtimer....
Windsor, ON, CA
Both of those codes can more or less be disregarded. I would clear them, then do some spirited driving and check again. They will probably be gone.
