Code 332 EGR
black93sho
Ohio
I just ran my codes and for the engine running codes I got a 332 (EGR did not open/respond during test or if memory code, did not open interrrmittantly). What does this mean? Do I have to clean the EGR valve or something?
SHOdownTN
Texas
It's most likely that the nostrils are stopped up on the inside of your intake. I would go that first. I did mine without removeing it from the car with a coat hanger and some carb cleaner.
Click the link markus gave you and it will explain it all. it's alot cheaper than swaping out parts and they not be the culprit.
poissonverte
iowa city, ia
I have to agree with ShodownTN.. I had a CE light with that code on for about a year.. I was lazy.. Finally decided to clean the nostrils (easy to get to with TB removed) and the lights been out since.. Thats after 40 bucks spent on a EGR regulator..... Oh well.
Markus
Ottawa, Ontario, Canada
I've never had a 332 code but I have cleaned my entire intake manifold twice. Both times the EGR nostrils were almost completely clogged. The second time I cleaned the manifold not only were the nostrils blocked but the passageways leading to the nostrils needed cleaning. Try cleaning your nostrils first and if that doesn't work you may want to remove the entire manifold and do a thorough cleaning.
