Cobra Rotors and 96 rotors
NJSHO
Clean Your Shorts!
NJ
Can anyone tell me if the hat offset of the 96 rotors and the 13" cobra rotors are the same? I am assuming they are since the mustang pbr calipers work with both. Also, If anyone happens to know the hat offset dimensions that would be helpful.
3.8Lwagon
Shaggen Wagon
i don't think the offset is the same. bc with the sho rotors part of the PBR bracket has to be ground away.
but a couple of grade 5 washers might be able to make up the differnce if u want ot switch back and forth.
NJSHO
Clean Your Shorts!
NJ
I wasnt sure if that part of the bracket thats ground was on the side that mates to the knuckle or the side the bolt head sits on.
3.8Lwagon
Shaggen Wagon
the part the mates to the knuckle needs to be ground down slightly. maybe 5 -10 mm.
