Clutch?
booztd
Pekin, IL
so i had my 89 out to day and got on it...no it is really hard to shift in to gear with the car running....i literally have to force it into gear....could this be because my clutch is not disengaging all the way or maybe low on fluid? someone help me please...also i do not know how to adjust my clutch...pointers?
JRA2000TL
The Complainer
Daphne, AL
These clutches are not hydraulic; thus, do not use fluid. To adjust the clutch, pull up on the pedal with your foot; then press down. If it clicks, it adjusted itself. Mine won't even pull up for some reason.
Others more knowledgeable will chime in, but I can tell you it's not clutch fluid, and it's probably not in need of a clutch adjustment. Mine can be hard to go in gear in the cold weather sometimes. I know you can siphon out the MTX fluid and reinstall new tranny fluid to have smoother shifts, but yours may be more serious.
Do you have to force it into all gears or just certain ones?
Vnuk1
Mr. Mayhem
Minnesota
Mine is a little tough at first but after it warms up it's fine. Some say different ATF will help this I have not tried it yet but will when spring hits and I dig mine out of the garage.
booztd
Pekin, IL
okay...i will change it asap but how do i do that is my next ?....this is my first sho
Vnuk1
Mr. Mayhem
Minnesota
The fill plug is on the front of the transmission (facing the front of the car)
its a 3/8's ratchet plug. use a 3 inch ext and be careful.
Once you change the fluid (by using regular ATF) you should notice improved shifts.
booztd
Pekin, IL
okay...found that...but is there any other way to adjust my clutch since the pedal saction doesnt work?
booztd
Pekin, IL
hmmm...well....idk....but is there no adjuster on the cable in the engine compartment and how do i find this quadrant thing? whats it look like?
