Clutch too tight
RJ-92
Crappy NYS
After installing a new motor in the beater (blue 95 MTX) I could barely get the clutch cable in the slot on the actuator lever. I had to pry the lever back about 1.5" to slide the cable in. I figured it was going to be an issue. I assume the clutch adjustor ratcheted down while the cable wan't connected. Now the clutch is way to tight. I"m not even sure in engages all the way. How do I losen up the adjustor? Do I need to take the pedal out?
Thanx in advalce.
AREA 91
PA SHO SHOP
Area 91
Put a wrench under the clutch pedal to hold it up. This will release the paul from the quadrant and allow you slack to engauge the cable onto the TOB fork.
I think he meant pawl, not paul... ;)
chevrolet
sommers in N.C.
mine did this after clutch service and stabbing the peddle full stroke a few times corrected this. A new clutch needs to be broken in/bedded and that means no hard pulls for 300mi. Can you drive it normal for 300mi?
