RJ-92
After installing a new motor in the beater (blue 95 MTX) I could barely get the clutch cable in the slot on the actuator lever. I had to pry the lever back about 1.5" to slide the cable in. I figured it was going to be an issue. I assume the clutch adjustor ratcheted down while the cable wan't connected. Now the clutch is way to tight. I"m not even sure in engages all the way. How do I losen up the adjustor? Do I need to take the pedal out?
Thanx in advalce.
Thanx in advalce.
