clutch switch????
lowc
aka vapah lock
Quincy, massachusettes
guys another atx to mtx swap question im trying to figure out how to splice in the clutch switch? there is no visible connectors tucked up under dash so do i just by pass the nutral safty wire off the ignition?
if you did the mod to the mlps on the trans, then you don't need the clutch switch - it will crank whenever you try. if you need the 'safety' of the interlock switch, you run the wires off the mlps to the clutch switch.
if you are using the 3.0 harness under the hood, you will need to either use the 3.0 dash harness or re-wire a bunch of the wires at that large connector under the mafs. part of what you will need to re-wire is to jumper the clutch interlock switch, if you go that route.
