Bank of SHO
I removed the tranny without incident and cleaned the outside of it pretty well. The case halves are sealed with black RTV, a lot of black RTV. cuss
I installed the TOB actuation shaft bushings and TOB. Here is my major concern. Using the release arm to cycle the TOB, it is smooth a couple of times, but then it binds. It seems the upper fork portion with the plastic pin pulls the TOB back to the case a little unevenly(i.e. the upper plastic pin half is pulled a little more than the lower half, thus causing it to bind). Yes, I did put the new sleave on with sleave retainer. I didn't put anything on the outer surface where the TOB rides.
I will finish the cluch installation and open the tranny today. I'm really worried about that TOB though. It would be quite unpleasant to have to tear this car apart again anytime soon.
Please advise. Thanks.
