clutch saftey switch go bad???
Dylan
Central NY
My dads 90 SHO wont start. And he belives its the clutch saftey switch. could this be true? he said it has happened where it wont start maybe 2-3 other times, but the last time was about a month ago. And all he had to do was get it pop started and it would be fine. I notice the switch has 2 wires coming out, could I cut the two wires together? Battery is fine so their should be no trouble their
What other reasons could be casuing this, Im sure theirs a million, so maybe just the more common ones for now. And if I have to get a new could I still get it from the ford dealer or do i have to find a used one somewheres.
Thanx for any help or info with this, for now where just push starting it and tring to park on hills and what not :nut:
Yes, that switch closes to allow the engine to crank, so you could jumper it to test it.
93rev2sev
Hockeytown
X2 Prolly not the switch. Try a new solinoid. It's pretty easy to check the switch, though. Just probe the wires with a volt meter and push the clutch in. You should see voltage.
Dylan
Central NY
YESSSSSSSSS it was the solinode, NOT the switch. My dad got a new one today and everything is fine.
Thanx a MILLION everybody :salute: You guys kept one more SHO on the road
