clutch pedal stiffness
jrock
Guest
wausau wisconsin
I know my clutch has been replaced and it grabs and shifts great.. The pedal seems like it could be easier to push, Is the a way to adjust it or maybe the fluid could be flushed and changed . Any ideas??
Mike93
Go Sabres!!!
Buffalo, NY
SHO's use cable actuation to work the clutch, therefore no fluid necessary. Perhaps the cable is 'dirty' and a new one is in order? I recently changed mine and the differences between the old and new were quite noticeable. $30 from a local auto parts store and about 30 minutes of labor...pretty straight forward job.
bdcmaverick
Omaha NE
Loose Clutch
Hello -
I have the opposite problem. My pedal is so loose it barely takes any effort to push it to the floor, and it engages at the very top of the pedal release motion.
It is a 91 and has been in the garage for a looooong time w/o driving it.
I had a new motor , clutch, TOB & release fork installed and I have been slowly getting the body work and interior redone. It is ready for paint but it doesn't feel right when I drive it.
I have been driving my 92 Dodge Stealth which has a very stiff pedal and a very low engagement point.
So my question is did I just forget how to drive this thing and all is OK, or is there a way to stiffen up my clutch pedal ? The lift pedal and wait for click isn't doing a damn thing.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Was the clutch you installed a CM Stage 1 kit? After installing mine, the pedal feel was light. With 600+ miles on it now, its much firmer. The high engagement point I just got used to.
