presidentpoo
when you install the cable and it says to prop up the pedal is that meaning keep it pushed in(disengages if it was connected) or to prop it up in the air where it would be if the clutch was engaged? I took the pedal off and found that the pawl had moved to the other side of the quadrant where the furthest it could move was just before the teeth met the quadrant teeth before actually pushing against the quadrant. i took the pawl off and got it to the other side and it is now teeth to teeth with the quadrant so i want to make sure i get the cable on correctly
