SASHO91
Zoom Zoom
Last night I found myself trying to limp the car home without a 100% functioning clutch.
What the car is doing... Start car.. try and select a gear, but nothing. However, I can start the car with it in gear and the clutch pressed and it will not move while I crank the car(it will move slightly, **** if you will, but it will not roll), and the car will move as soon as I start to let the clutch out. However, it releases very low... MUCH lower then stock.
IIRC, the last time my clutch went out (or the TOB went out) if I started the car while in gear and the clutch pressed it would still roll. And yes, I do know the damage that can be done by doing this, I had no other choice.
So does this sound like a clutch problem(disc/PP), TOB, or clutch cable problem?
Also, this clutch has been acting up since I put it in a few months back. Slight grinding between gear changes, and slow gear changes as well. It would only do it on occasion and not every shift.
