sho thing
I'm going to dive into a clutch job later today. This will be my first time getting this deep into the car. I did the 60K myself, so my knuckles are toughened from that skinning.
I know that overall, you need to support the engine in place, remove the subframe, then take the tranny off the engine. Some people here have said that they support the engine on blocks under the oilpan, instead of having some specail apparatus to hang it from above. Since I have no apparatus, this is what I was planning on doing. In looking at it though, it seems that having a tower of blocks from floor to oil pan will capture the subframe when it is removed. Do you just work around it? Seems like a real PIA when you're laid out under the car trying now to get the tranny off, and then it would prevent you from being able to roll the tranny away on something. Can you lift the tranny by hand? Am I missing something?
My second concern is with actually separating the tranny from the engine. Seems like no matter how well you support the tranny while you're removing the bolts between it and the engine, it will want to shift once it is totally free from the engine, so when you're removing the last bolt, the tranny is basically dangling from the engine by that one bolt. Seems like the weight of the tranny would just shear out the last few threads instead of pausing politely before falling while you got the bolt all the way out. Or does the tranny stay in place with the bolts gone by dowels or tabs or something. If it does that, is there a special way you're supposed to finally disengage it? I have the Helm manual, but it's quite lacking in specifics here.
thanks,
Justin
thanks,
Justin
Oh, well.
I did, afterall, do the entire thing by myself.
