ctm78
My 94 MTX is having some type of tranny issue. . .I've been told a bunch of different things. Here are the symptoms:
* Very difficult to put the car into gear, takes some pretty good force to push/pull the shifter into gear.
* I cannot shift into reverse anymore with the engine running without reverse grind. . .even if I go into a forward gear first.
* Without the engine running, it is easy to shift gears.
* There is no regular grinding. (Sometimes when the engine is cold, there will be a light grind when downshifting at a stop.)
* 127K miles, I've had her since 92K. (She has a trailer hitch, so I find it hard to believe this is the original clutch.)
First I thought the synchros may be going, along with the TOB. Today I talked to Performance Plus (they're great. . .highly recommend) and they suggested that it may be as simple as the clutch not fully engaging? (Which would be much better since rumor has it that synchros aren't available anymore.)
Any ideas or thoughts? Anything else I should test to zero in on the problem? Could this be as simple as adjusting the clutch cable? (I do the manual pedal pull occassionally, never more than one click.)
