Yeah, there was a lot. It's nasty stuff. Add to that all the packing grease left in the innards of the Quaife...I removed the stuff on the Quaife's outers. At least where it mattered.
It's really not pleasant at all using brake cleaner, acetone, and Berryman's when it's 32 degrees out. It doesn't evaporate before your eyes like in the sun of course. I get stingy with the air compressor in the wee hours because I don't feel like being *that* mean to the neighbors renting the nearby appartments that overlook my garage and back parking area...plus my backyard. I told them I wanted them to put in a 12 foot fence when they built that damn building! Oh, and evaporating solvent liberates heat from metal just as well when it's 32 degrees as when it's 82. Frozen metal, freezing my paws and condensing corrosion causing moisture (if I don't see it at 2am I'll daydream that it's happening...j/k but not completely), then putting the parts under hot lamps to raise the dewpoint local to the warming metal...Bad enough cleaning the original parts, still in fine shape at 200,000 miles. It didn't take many excuses to keep me from repeating for the new parts with that nasty factory goo.
I've got somewhere between 150 and 200 miles on it since last night. 50 miles of basic "gotta do those first break-in miles to make sure" last night and took the wife down to Big Sur today since I've been neglecting her for the past couple of months. World's slowest amateur mechanic here. For every hour I planned I took 6. At least. Cleaning bolts, washing dirt and chicken crap off my driveway so it wouldn't blow into my exposed motor during rod bearing replacement...and not having enough time left to get started on the rod bearings that day or night...don't ask me to count how many times I screwed myself over by squandering precious time that way. ****, I spent hours stewing over what would be the best grease to use for my clutch TOB shaft bushings. Used my nasty thick n sticky teflon fortified silicone grease I use on my suspension bushings. It's so sticky it could qualify as glue rather than a lubricant. It's so viscuous I doubt its flow can be measured. It will stay put and last, or so I hope. Dampen noise better than other grease I reasoned. Keep the TOB fork from moving of its own will. Sure it takes more effort to move the lever by hand with the tranny out but that additional force requirement is insignicant to the force of the foot to the floor and the the fingers pushing back....**** the grease sticktion might be working for me on the pedal upstroke. Another insignificant detail. And I even had a backup plan in case that grease didn't work out. By luck I discovered that ATF is the best way to clean that grease off something. Seriously, it is really hard to get off the paws....although permatex fast orange cleaner turns out to work pretty good too. Well, a few drops of ATF mixed with my sticky teflon silicone grease becomes very slick. Some on the felt washer to work down into the top bushing, and using a mirror and fishing a semi-rigid bendable hose through the hole for the starter pinion to get a few drops of ATF on the shaft above the bottom bushing...that was my backup plan for a grease decision gone bad to save from pulling the tranny. Well, my crazy reasoning worked out and the grease works great and it should last a long long time. But the hours stewing over it, well, I'm only getting older and those hours are gone. Another way to look at it is the ridiculously slow pace at which I worked has pretty much gotten me through all of winter. I put the car on jackstands on X-mas Eve I believe.
Oops, book writing again and should save it for another thread.
Nasty packing grease, yes yes. Very nasty factory packing grease.
