Clock on Dash not Working
EddieO
Louisville,KY
Anyone know how to replace the clock on the dash board? My digital clock quit working. Completely black.
Eddie
RickieFrat
La Cosa Nostra
State of Corruption - RI
Most of the time its just a bulb. Can you still see the time ? If not you might be better off going to a junk yard before heading to the dealership.
1992 TAURUS SHO **FOR-SALE**
Red/Grey Int
20% Tint
PIAA HeadLights
Boxless
1200 Watt System .... 131. DBs
Sig Pic By SHOTIME (THX)
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
www.fratsperformance.com
faxon
Seattle, WA
It's not hard at all. Assuming you have a gen II, there is a lazy man's way to do it: Grasp the black plastic above the EATC and pull out. It should be clear from there. You can break your dash at that, but all the cars I have done that to in the junkyard have never had a problem. The right way to do this is unbolt the metal plate under the steering column, pull the headlight **** off, unscrew the screws above the instruments, unscrew the screws attatched to the plate that sorrounds the clock bt the steering column and then pull. I would definately try the junkyard for this part.
nothingtoseehere
Are your power window and door lock buttons lighting up? If not, both will light back up with a 10 amp fuse. The both run from the same fuse.
-RANDY-
