Climate Control Problem...Please Help
shoRunner
GA
It seems my climate control(EATC) has developed a problem. It won't turn off. I'll press the button and it'll say off on the screen, but the blower will be going full blast. It could be a blower problem I guess, but i'm not exactly sure. It has not other setting than full blast i'll move it to low and nothing will happen. It will respond to changing the temperature on the climate control, like if i turn it to A/C then its cold, but still full blast....ANY help would be good.
30footSHO
In da mountains
Boise, ID
It's your blower motor. About a $35 part and you can replace it yourself. It's located behind the glovebox, in the heating ducts.
Also, do a search on blower motors; I know someone on this list has been fixing them.
I had the same problem, but I can assure you the temperature here is at least 40 degrees cooler than GA... my problems stem from the cold.
Dave
LaTechSHO
Louisiana
actually rather than being the blower motor.... i would imagine it is the blower control module...
very expensive if bought new from ford, but someone on here ought to be willing to part with one for a decent price
Louis
30footSHO
In da mountains
Boise, ID
that's what I meant. BSCM for short.
My Bad thumbs_u
Try Al Fitz; he quoted me $35 for one.
Dave
<small>[ February 11, 2003, 05:05 PM: Message edited by: 30footSHO ]</small>
projectSHO89
SHOless In St L
You can get this part from any boneyard Taurus that has an automatic climate control. It is not SHO specific.
At a self-serve yard around here, $10-15 max.
Steve
<small>[ February 12, 2003, 09:15 AM: Message edited by: projectSHO89 ]</small>
shoRunner
GA
Thanks guys, I guess I'll be heading out to the junkyard ASAP.
shoRunner
GA
oh yeah 4.71, and I'm fixed...now lets have all my SHO problems cost this much to fix.
