Climate Control Light? Help!
Brian685
Philadelphia
Hey guys, recently as I was installing my cd player, I had the upper portion of the dash on my '89 partially unclipped which I slightly flexed to install the cd player, afterwards I pressed back on it to clip it back in, and -snap- it all popped back in one shot.
I started putting in the screws but I thought I'd make sure everything worked first. Turned the car on and everything lit, except my Climate Control backlight. At first I could just BARELY read it. A few minutes later I couldn't read it at all. Could I have broken the light / unhooked it? How exactly is it set up and what are my options! Thanks.
- Brian
Currant Red '89
98k miles Stock
Brian685
Philadelphia
Oh GAWD! I finally got to the light! I had to pull the entire dash to get at the climate control, then the face of the CC had to come off, then the circuit board just to get that bulb. Pulled it out as I await the opening of the dealership on wednesday. Pep Boys doesn't carry the light.
Wow, for my first "working on" my car, quite an experience.
Any tips on dash re-assembly? I plan to tackle it on wednesday.
- Brian
Currant Red '89
98k miles Stock
SHO SPD
SHO member #480
Naples, Florida
Its not a hard job, the dash is an easier thing to take care of, also Napa auto parts carries the bulbs in stock, but you need to take the bulb out of the grey piece that it rests in, you can only replace the BULB, not the grey socket thing, it will pull pretty hard most likely, but it does come out. then just go get a new bulb, they are like $1.00. Good luck, and when you put the dash back on, remember too hook up the clock
1989 Titanium pearl
CAI
K&N cone filter
Slicers (thanx to G/F)
JBL speakers (thanks Adam) ;)
G-tech times
0-60....6.61 sec.
1/[email protected] MPH
Jan. 10 1:15pm
