Alright here is the problem. My blower fan seems to only work when it is turned all the way up. Even when the auto temp is activated the fan will kick on and off only on high. When I do switch the system to defrost or any other setting and turn the fan up all the lights go dim while it switches on then go back to normal a second later. I ran the test on the system it came out no problems. Any suggestions.
