Climate control goes crazy!!
bigbadfords
Shamokin, pa
Anyone ever have this happen....all climate control buttons off, meaning no power to anything related to climate control, correct?? At random times the climate control display will flash random numbers and symbols like crazy even with everything turned off....what the **** is causing this?? Any ideas? Thanks guys!!
Might be a bad cc unit or an electrical short. Sounds like you have your hands full.
If it is just the CC doing this then the problem is with the CC. Take it out and see if all the connectors are clean and tight. Over the years I've had to replace two of the footballs for different reasons.
bigbadfords
Shamokin, pa
Yes its just the CC doing it, no other electrical problems (that i am aware of). I will do as you said and pull out the unit and check all connectors. Thanks SHOZ, your input is greatly appreciated.
