climate control exterior temperature reading
Bank of SHO
Vegas
After finishing the clutch service, the exterior temperature reading shows a constant 99 degrees. How should this be trouble-shooted?
Intermittent Heating and Cooling. Outside Temperature Display Sometimes Inaccurate
Possible Source(s):
2. Sensor wire harness open or shorted.
Action(s) to Take:
Disconnect battery cables. Disconnect wire harness connector from sensor and disconnect both connectors from the control assembly.
Inspect for crimped terminals.
Check for continuity and for possible shorting between the two wire (Pins 1 and 2). Service if necessary. Reconnect wire harness and battery cables.
SHOguy 92
Duluth, MN
i know this is off subject but i just noticed that SHOZ12 gives out his exact to the spot coordinates so if anyones board try and find him lol.
