clicking sound under the dash
Cocoa,Florida
ok,for a while ive been trying to find why my dash lights on my 91
are not working,ive replaced the headlight switch,dimmer,and auto lamp.
and still no luck,so what im wondering is what is the clicking sound from under the dash when i turn on my lights?
could that be the reason why the dash lights are not working?
im stumped i have no more ideas??????
just a little recap:just the dash/instrument lights are not working
parking lights all work as do the tailights just the small lights that light up the EATC,gauges and around the headlight switch fog light switch defrost switch
IM STUMPED PLEASE HELP!!!!!!!!!!!
crazy_canadian
Rattle-Mobile
Quebec
I dont think the clicking is not normal.
When my lights turn on with the auto lamps fonction, it does click.
american212001
Michigan
the clicking may have something to do with it, however my heater clicks everytime I turn my key forward, and everything on my car works.
ok a couple of questions,
did u check the fuse?
does the clock on ur dash work?
lastly,
where about is the clicking coming from?
once u let me know I can try to help u solve the problem.
Cocoa,Florida
yes i have checked the fuse,its fine
the clock does work and does light up when the head light switch is in the off position as does the EATC
clicking sound seems to come from the glove box area,when i swing the glove box door all the way down the is a blue box that has some wires running into it...i think its coming from that?
american212001
Michigan
So the clicking only happends when u turn on your lights? If thats the case it may just be a loose wire near that area, seeings how the computer is right behind the glove box.
another thing u couold do in the mean time is easiest this first, and that would be, making sure that the wire is connected behind the fuse box.
wood_e
The dude
Ames, IA
I've got a clicking too when I disconnect my battery for more than an hour. It does away though after a while... I have no clue what it is.
SlowHeavyObject
philly
try checking the stupid flasher relay/circuit breaker or whatever it's called. i know in fords that they wire that damn thing into everything. happened twice to me. once in my mustang and once in my taurus. they wire the instrument lights to it cause of the L/R turn signal indicators on your dash. mine was going bad and my signals would work intermittently and sluggishly sometimes. i think the clicking you hear is from the relay itself which is like a sky-bluish color and is located behind the glove box when you drop it. it is totally separate from that round thing in your fuse box. once i replaced it, no problems at all. you can get a ford replacement which is the better part but any pep boys bought relay will do. just remember that if you don't buy the ford one the speed of your turn signal flashes will be different than what you're used to. hope that helps, it's the only theory i have. :shrug:
edit - got a good look at it just now and it is round and sky-blue and is attached to the metal frame of the dash on the left side of the glove box when you push in the sides of the box and drop it all the way (looks just like a regular flasher module). has 3 flat pins in a triangular pattern and unplugs from a harness and has one of those door panel type fasteners that goes in a hole in the metal dash to keep it from flopping around.
Cocoa,Florida
so i figured out the problem i had....get this.....
i had 3 bad dimmer switchs.....WTF,started testing things with a voltmeter
and found that i had power going into the dimmer so i got a dimmer out of my buddys moms Sable.....**** problem solved!!! 3 bad switchs is that some BS or what???????????
