Clicking noise?
Matthardin86
Winder Georgia
I have a 2014. Beginning of the year I changed control arms, strut assemblies, sway bar links, tie rods ends ends. This past week I noticed a clicking noise when turning in and out of parking spots. Changed both front cv axles tonight and clicking is still there. I’m at a loss for what it is. Anyone got any ideas??
2K16SHO
Rochester, NY
I had something very similar, a distinct ticking sound when turning the wheels when barely moving or even sitting still. I noticed it most when pulling in and out of the garage. Turned out to be the driver's side wheel bearing/hub assembly for me. Only about 35k miles on the car at the time.
kryptto
South East, Florida
another idea is upper strut mount, a suggestion is a goPro and start finding places to observe and listen for
TDS-MN
Minneapolis, MN
I actually had a similar noise once, and found a couple loose lug nuts. Definitely went away after I tightened those. Just a suggestion to check simple things before worrying that it might be something major.
Tbird6
Here is a copy.
  • TSB-14-0186-Pop-Click Noise Front Halfshaft.pdf
cobra93
Toledo, Ohio
I had a click on my '17.
Mostly happened when the wheel was turned and I was going between drive and reverse.
Like backing into the driveway.
It was the "strut bearing" or mounting plate for the top of the strut.
Good luck sorting it out.
Matthardin86
Winder Georgia
Yep. I replaced complete strut assemblies.
hosbaldosho
