Cleaning Intake
Toneboski
Ipswich, Mass
Hey guys, Did a search and saw bits and pieces of my topic around and wanted to see if you guys could give me a concise roundup of what to do. I'm looking to clean my intake and i've seen that berryman's is used. What is the process and what do I need? Thanks.
Markus
Ottawa, Ontario, Canada
Toneboski:
I just finshed cleaning mine. I used 2 cans of carb cleaner, a bottle brush, a clean rag, and a soft-bristled detailing brush. I took the manifold apart and removed the throttle body (TB) and idle air bypass (IAB) valve. Then I:
1) Pushed a rag soaked in cleaner through all passages. This removed the grit from the walls of the passages.
2) Sprayed the cleaner onto all passage walls and scrubbed them with the bottle brush. I used the detailing brush to get to areas where the bottle brush did not sufficiently clean.
3) Rinsed everything with water
4) Used bottle brush with diluted dishwashing detergent. Rinsed and dried.
5) Removed the allen screws on the EGR tubes (within the manifold) and cleaned those tubes. The EGR outlet nostrils (inside the manifold) were 75% clogged. I know you have an MTX and probably don't have an EGR valve but I included this step incase you do have one.
6) Cleaned all the rubber connectors and their circular clamps with diluted dish washing detergent.
7) Cleaned the TB with dishwashing detergent. This took a while but I did not want to use stronger chemicals as they would have removed the anti-sludge coating. The TB was very dirty -both the small PCV ports were completely clogged.
When I first cleaned the intake (in 2000) I was able to reuse all gaskets. This time the gaskets broke when I tried to remove them.
I did not clean the IAB because it did not appear dirty, it has been performing properly, and because I did not want to remove the internal anti-sludge coating.
The whole process consumed about 3 hours.
For information on how to actually remove the manifold can be found by searching this forum.
rendyx
Buffalo, NY
Get about 10 cans of Berryman's (not the FI cleaner, the spray stuff), and a bottle brush. And a roll of paper towels for the heck of it. You might pick up a plastic tarp for cheap if you don't want to destroy the floor/ground you're working on for a 10' radius. wink Oh, and some plastic gloves too!
Basically, rip off the intake, take off the throttle body and crossover tube (the tube on the passenger side), and the runners if you want to. Now, spray B12 into the intake pieces, get them all drowned in it (NOT the outside), and then bottle brush it out. Use the paper towels to clean up B12 on the outside. You have a few minutes for the B12 to touch the intake's finish before it begins to eat it away. This happened to me, because the intake was sitting in B12 and I didn't know it until an hour later. eek! Anywho, dump the B12 out onto the plastic, and repeat until it looks clean and fairly dry. Get fresh air too, I have heard bad stories about what the cleaner will do to you! Clean all the parts, reassemble, and clean the intake so it's dry with paper towels, and water or degreaser on the outside if needed. Good luck!
Here's what to expect to see:
http://users.superford.org/rendyx/images/upper_60k/P1010019.JPG
http://users.superford.org/rendyx/images/upper_60k/P1010020.JPG
http://users.superford.org/rendyx/images/upper_60k/P1010022.JPG
http://users.superford.org/rendyx/images/upper_60k/P1010023.JPG
http://users.superford.org/rendyx/images/upper_60k/P1010024.JPG
http://users.superford.org/rendyx/images/upper_60k/P1010025.JPG
http://users.superford.org/rendyx/images/upper_60k/P1010026.JPG
http://users.superford.org/rendyx/images/upper_60k/P1010027.JPG
<small>[ April 12, 2003, 10:43 PM: Message edited by: rendyx ]</small>
svtC_and_SHO_Owner
Oregon
i just cleaned mine this weekend too! i used a pressure washer to speed things up in addtion to what has been mentioned. it runs much better now. its all so a good idea to change the spark plugs when you got the intake off, at least thats what i just did. hope this helps
mikiedreb
Benicia, California
I went through this process a month or so ago. I decided to disassemble the two manifold halves at the 6 black rubber connectors. As it turned out, they all cracked....hardened due to heat and age I guess. Ford no longer carries them, so I ended up ordering 1 foot of 1.75" dia silicone hose from Baker Engineering here in Calif. $15 later, I've got some cool looking blue connector hoses, and the manifold is way clean.
Mike
92MTX
Bizzy
mikiedreb:
Mike
92MTX
They have a website? I wanted to replace the hoses on my intake, but I'm not up for paying S H O shop prices for hose. Mine aren't cracked yet, but I don't like the looks of the black ones and blue would go much better with the silver powder coating I'm having done.
