Billy P
I followed the shotimes article on cleaning the EGR tube and it was as easy as advertised. I put it all back together and took it for a spin down the road (about 2 miles). All was good. The next morning, I drove it to work and it started sputtering when I gave it a good push on the gas. It got worse the more I drove (warmer the engine got). I brought it home and took it all apart again. Checked for debris and all that, even used a vacuum to suck anything possible out of the intake valves and piston cavity (got a real cool computer vacuum with hoses that fit nicley down the spark plug holes). Then I rechecked all my hoses and put it back together. Started it and it sounded normal. Then I put it in gear and started to drive and the sputtering returned. I put it on the ramps and crawled under it while it was running and the sputtering was coming directly from the front cat! Do I have a toasted cat? Did I mix the hoses up on the intake? Even If I did, it would just be the cooling system because I know I did not mix a cooling a vacuum line. Anyone have any ideas on what happened? Before the EGR cleaning I had no problems other than a Check Engine Light (which is now gone). Thanks ahead of time.
Billy
Billy
