Zap
Greetings,
The '95 is in pieces for its Front 60k, and I am curious about the removal and replacement of the CID sensor seal. I'm back at school, so I am going to be tackling the remainder of the Front 60k next weekend. In the SHOPP guide it shows 8mm bolts being removed, however my CID has much smaller bolts on it. Can anyone tell me if that is removing not only the plastic sensor piece, but the metal piece that it bolts to as well? It looks to be that way, but I want to make sure before I remove something that I shouldn't touch. (and the bolts on it are actually 8mm). That is topped by the fact that my CID sensor itself is OK but one of its tiny bolt heads is stripped (one of a few on this car, someone in the past wasn't very careful
) and I need to replace the seal.
Also, are there any suggestions for removing the water pump pulley after the belts are off? I don't have a "strap wrench" and only one of the four bolts would even budge (trying the other three resulted in me turning the engine via the WP pulley, so that was a lost cause anyway.
I've decided that the WP isn't something I want to fail on me, and it appears that the gasket between the front and rear halves is starting to age (it feels slightly damp on the bottom side). However, my decision for whether I should replace everything or not sat on the fact that I'm a bit short on cash right now and it appears that a 60k was done on this engine in the past, including the replacement of apparently ALL front end parts!
I've never had CPS troubles so far, and I'm wondering how long it takes AutoZone to get one in. RockAuto should be delivering my WP and gasket set soon, so the only replacement part I don't have is the CPS, not to mention that it has one screw that won't budge and appears stripped. I looked at the shop manual procedure for just replacing the CPS, and it doesn't look too bad. I think the fact that I would probably be stranded is worse than having to just replace the sensor. What's the verdict on this?
Thanks!
) and I need to replace the seal.Also, are there any suggestions for removing the water pump pulley after the belts are off? I don't have a "strap wrench" and only one of the four bolts would even budge (trying the other three resulted in me turning the engine via the WP pulley, so that was a lost cause anyway.
)I've decided that the WP isn't something I want to fail on me, and it appears that the gasket between the front and rear halves is starting to age (it feels slightly damp on the bottom side). However, my decision for whether I should replace everything or not sat on the fact that I'm a bit short on cash right now and it appears that a 60k was done on this engine in the past, including the replacement of apparently ALL front end parts!
Thanks!
