Mike Stitzer
Ever since I got a new clutch for my 95 at idle you can hear it chattering away lightly. It's the same sound as the typical driveline snatch that you hear as you pull away in a MTX SHO. Only occurs at idle and in neutral. As soon as I depress the pedal it goes silent. Is there a reason for this or is it just the way it is? It's dependant on rpm. If I hear it at idle and then give it gas to raise rpm it goes away. The clutch otherwise is fine other than getting that vibration at higher rpms while shirfting, which I'm used to by now.
Mike
Mike
