Checking Transmission Fluid
dinojc86
New York
Hi everyone, I have my 2015 about a month and I finally found the transmission fluid "dip stick". Down below the air filer. So, what is the procedure to check your trans fluid? Do you need to remove the air filter unit every time to check it?
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
The checking is just like any transmission fluid, warm cycle through gears three times slowly and check quantity.
You don't have to remove the air filter box but it helps. At least remove the upper section and set aside.
Johnbigdog
michigain
If you want to be specific, the transmission oil should be set when the transmission oil temperature is between 180-200° F.
How would someone look at the temp? Scan tool.
Don't have a scan tool, drive it check the level like above.
brucelinc
Minnesota
I had a trans temp gauge on my MKS. It takes about 30 minutes of driving to reach the appropriate temp. Also, check with the engine running.
