Cheap Driving Lights
SHOpar
Aloha (Portland), OR USA
Hey Everyone,
I found the PERFECT set of cheap driving lights for the Gen II SHO yesterday! They are Optronics Pro Series QH-17CT, and cost me $29.99 at Baxter's autoparts. The lights actually fill our foglight holes slightly better than our stock lights, and and they look completely stock. Installation was a snap, and the only other item I had to buy was a 5/16" fender washer to mount the driving light using the large hole at the back of the foglight bracket. The part that took the longest was soldering the new driving light wires into the OEM foglight wiring connectors. I'll try and get some pics and post them for you all to see.
The lights can be seen here:
Optronics
Baxter's Autoparts is a NW Oregon/SW Oregon auto parts store, and their page can be found here:
Baxter Auto Parts
The lights still run a 55W bulb, so heat and wire melting issues won't be a concern, yet they throw out an unbelievable amount of light. They work better than my highbeams by far, and are aimed low enough to not offend oncoming traffic (I had them on all last night driving around Portland without getting flashed by oncoming traffic). I finally can see where I'm going on dark roads, and now I'm really motivated to get new headlight housings and install some Silver Star headlight bulbs. thumb
I know they won't last forever, and a set of Piaas would be better quality and likely have even better light output, but I couldn't find any Piaas that looked stock (high priority), and I certainly didn't want to spend $200+. IMO, the Optronics look much better than the Blazers, and I think they are slightly higher quality. At $30 a set, I can go out and just buy a new set when the bulbs burn out or the lenses fog up! :D
Let me know if you guys want a set and can't locate any!
<small>[ July 21, 2003, 01:11 AM: Message edited by: SHOpar ]</small>
Slo-Sho
It wasn't me!
Crossroads, CNY
Ooooh, nice. Did you use relays, they'd be just that much brighter if you hooked them right to the battery. Same principle as a high current headlamp harness.
<small>[ July 20, 2003, 01:24 PM: Message edited by: Slo-Sho ]</small>
shoinoff95
Wichita, KS
Good work SHOpar on finding a cheap replacement for the gen2 other than the blazers, which sound like more work to make them fit to the gen2 fog light assembly. thumb And since they are a driving light, they should be brighter than just regular fog lights!
BlackOnBlackATX
Dutchess County, NY
shoinoff95:
SHOpar, how bright are these bad boys, i have a set of blazers in my garage but im thinking about ditching them and getting the hella direct replacements. let us know how these fare up! thanks man!
SHOpar
BlackOnBlackATX:
They are really bright! They put my headlights to shame, but that's not saying much, considering how clouded and pitted they are. Overall, I am very pleased with them.
I installed a set on a friend of mine's SHO and took plenty of pictures today. Over the next couple of days I am going to do a nice write-up. Maybe I can even get it on the SHOtimes FAQ when I'm done! thumb
Blue-By-U
CT
I'm debating on whether to get the Hellas from SP Motorsports or the ones you listed above. Anybody seen the Hellas in person?
