Changing Water Pump?
KentuckySHOoff
Bardstown,KY,
Ok - how long of a job am I looking and is it neccesary to remove the crank bolt? probably a stupid guestion sorry. Any one in kentucky or surrounding area want to help? thumbs_u
projectSHO89
SHOless In St L
Five minutes, normally.
Remove the rt front tire, put a 19 mm impact socket and a ratchet on the bolt head leaving several inches before the handle hits the subframe, disconnect the DIS module, bump the starter. Works every time as long as the ratchet doesn't break.
Steve
SHOemup
Dalton, PA
The job will take about four hours. As for the crank bolt, you can consider doing it the safe way. borrow or rent a 1 in torque wrench. 1/2 wrench wasn't strong enough for my car and I had to do the method described in the previous post. You have to take apart most of the passenger side of the engine bay. You might as well change accessory belts, timing belt, crank sensor, and front main seal while you're in there. After you do this now, you're going to be upset when you have to do it again. I'd get it all over with now. Just for the record, it took me 6 hours to do the job.
bbeechsho
Louisville, KY
I'm in the process of doing mine now on a 93 ATX. It has taken me days!!! I was just going to change the waterpump, but after i had it all down, i realized how much easier it would be to change all of the other things now. So naturally, I had to HUNT down parts. Good luck, and it's really not that hard of a job, just time consuming.
SHONUT91
Cameron,Mo.
I am just finishing my 60k,bring it to my house and I will help you.I have a heated garage and all necessary tools.Let me know,don't forget to get your parts ordered because most auto parts stores don't stock parts for our cars.
SHO--ripper
928 Euro
winsted,CT
"don't forget to get your parts ordered because most auto parts stores don't stock parts for our cars. "
Very true. the stores act like they can get the parts, you order the parts and they are the wrong ones. order online from a strickly FORD/SHO distributor.
SHO--ripper:
But many of the parts can be purchased through local auto parts stores. I have posted the list of sources many times. Search on "60K replacement parts" or just look here.
