changing the thermostat
Big Mike 74
Stupid question but for those of you that have done it, where is the thermostat in these and how long did it take to change....thanks in advance!!!
Orguss
San Francisco, CA
Be aware that, although someone posted that just a little anti-freeze comes out, I lost quite a bit after pulling off the hose. Be prepared for that--have a bucket under the car.
Really only worth it if you have a tune, to take advantage of the TStat opening early and turning the fans on earlier.
subframe
New Hanpshire
When I changed my thermostat I jacked up the drivers side of the car so when I removed the housing, not much came out ....maybe 2 cups.......Rich
sticks1680
Old thread but. Trying to fit this into my schedule this week. Going to order thermo monday. How long does it take to remove the stock airbox enough to get it out of the way to install this? Im working nights so time is limited.
Pohnz-1
EcoBoostSHO
Minnesota
5-10 minutes. Two bolts up front. (8mm socket), unplug IAT sensor, loosen worm clamps and remove.
