DALLAS C SHANK
When I pull the plug is the fluid supposed to come out on its own? Cause mine did! Also how do we go about putting more back in, and how much does it hold??
Also, are you filling the PTU while the car is level? I know it sounds basic but I've had a buddy try to fill his transmission while one side was on a jack stand.
The 2010 only has one hole for filling and drain about halfway up the case. There isn't a drain plug per say.
Okay so you pulled the plug and fluid came out...It could have been overfilled by someone with the car at an angle previously OR you could have a bad seal between the trans and the PTU and transmission fluid is being forced into the PTU. I recommend you check your transmission fluid level. As someone mentioned there was a TSB for it during the early years. The fluid level should be even with the bottom of the fill plug.
So I have to ask since you said it was coming back out the hole - Did you actually pump out all of the fluid through the hole with a hand pump and hose that reaches down in to the bottom of the PTU? It isn't fun but you have to pump the old stuff out THEN pump new stuff back in through the hole until it just starts coming out of the hole...then you are done (assuming the car is level). Just put the plug back in and call it good.
