Changing my cam sensor tomorrow
SeanMc
NoMoSHO
Any tips? This is the first time I've done this, and the sensor on there looks like the original.
I ordered one online from RCM, it came in a plastic bag, wrapped in newspaper, with black ink covering up what looked to be some numbers. I was expecting something in a box and new looking. :shrug:
wood_e
The dude
Ames, IA
RCM is a good organization. The sensor is really easy to change. All you have to do is unplug the old one, take out the securing bolts, then take the old one out and put the new one back in its place.
yamahaSHO
E85 whore
Arkansas
Mike, there is no gapping of the cam sensor... You simply take the plastic sensor off with two 5.5mm bolts and replace. It is an extremely easy job, just a rather tight fit.
It helps to move the power steering reservoir out of the way and the cross-over tube.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I can help you with it. I have done my cams enough to know how to do it. If you need help let me know.
Shuey
MidWest
If you have an mtx, u also need to remove the engine dampner and other misc.
Electricat
Decatur, IL
Be careful about overtightening the bolts, it is easy to strip out the holes.....not that I would know anything about that, it happened to, ummm....a friend! :bonk:
SeanMc
NoMoSHO
Since I can't afford a new IAC right now, maybe we'll just take mine off and clean it along with my MAF. I'm looking forward to today :).
Tell Elec...um..I mean, your friend....he's a ***** :biggrin:
