PAracer said:The 176 refers to the front o2 sensor. You should be able to take care of that with the car on ramps and a wrench. There is a special socket for the sensor that you can get from most parts stores. I happen to know that Autozones have the Bosch sensors in stock. The part number is 15729, IIRC.
Fixing that code is easy and may get rid of other codes.
The 214, CID code is not so bad either. It is most likely a leaky cam seal fouling the sensor. The purpose of the CID sensor is to determine the location of the cam lobes when starting the engine. With a bad sensor, the motor will crank over a few times before firing off. You can certainly drive a while with a bad sensor. To remove it, the power steering resivior must be unbolted and moved out of the way (2 bolts, IIRC). Same goes with the intake crossover (4 hose clamps, 2 bolts). The sensor itself is a pain to get to, but is only held by two screws.
If you'd like to come down to West Chester, I'd be glad to check out the car and take care of the o2 sensor for you.
This weekend is good for me, except for Sunday afternoon of course.
PAracer said:If it has been rebuilt, maybe it is still being broken in. Unfortunately, some people just aren't honest. I would suggest that when you check the fluid level that you should also smell it. Bad/old fluid would have a burnt smell. If the fluid is old, then you can assume that it may not have been rebuilt. For insurance, you could change the fluid and add a bottle of Lucas Transmission fix. I gave that stuff a shot last summer, and I think it may have been a little help.
If you need a shop near school, you might try DML Automotive (attached to the BP station next to the Holiday Inn). I bought my ATX from one of the mechanics there. If you go there, tell them that you know the guys up the street with the SHOs. They have some experience with the cars. Unfortunatley, there aren'y too many good parts stores around town. Tabor is pretty good just off Bolmar street. Fred Beans Ford has been great for parts too. Neither place has SHO stuff in stock, but most common things can be available within a day.
It's easier with the intake off but can be done on the car with a peice of coat hanger and carb cleaner.fkirk1 said:I'd appreciate your tips on cleaning the EGR passage.
