CE Code, 214, whats it mean?
LiLGhettoSmurf
Owego, NY
214 - Error in Cylinder ID (CID) circuit or signal
When the light is on at idle the car jumps from 500 rpm - 1000 rpm, If I try to drive it with the CE light on it does a bucking, like it has normal power than loses power, normal power, then loses power.
ohfosho
ontario SHOwner
ontario, canada
if the engine is noticeably missing, and it is not just the tach missreading/stuttering, then it is the coil pack
projectSHO89
SHOless In St L
Far more likely to be the CID sensor than a coil pack.
Coil packs just don't fail very often. CID failures are common and the usual symptoms are present.
Steve
