Well go here and down to post #18...that's where this all started.
I've researched and found a few documents and threads about the relay module, but nothing comprehensive. It may be out there, but I can't find it.
http://http://www.shoforum.com/showthread.php?t=128464
I opened up my relay module today and have a few initial observations.
- the relays are PCB (printed circuit board) version of standard spade-terminal relays you'd buy at any parts house.
- these PCB-mount relays are not at all easy to find (but I have)
- the circuitry itself inside the module is extremely simple (it's not much beyond the relays besides reverse polarity diodes and a regulator circuit.
- (2) relays are for the fans (lo and hi), and (2) relays are for A/C clutch and fuel pump.
- (2) relays are Omron 12V, 20A, SPST, (2) relays are Bosch 12V, 40A, SPST
- SPST is single pole, single throw
- The part numbers on the relays themselves will not likely get you to a place where you can actually purchase them, but thankfully I have cross-reference material that helps me find what the real part numbers are.
- The relays are available, but not in the US
- In the grand scheme of electronics repairs, there are only (6) parts worth changing in the module...(4) relays and (2) electrolytic capacitors
The documents I downloaded to go off of had some incorrect information actually. The 24-pin connector of the module is incorrect, and the internal diagram was also incorrectly labeled. (1) was made by an individual and the other looked like a factory document.
I'll get all this straightened out, but I'm working from a J-code CCRM in a '94 auto tranny car.
Pictures...
Pictures...
No loitering!!!
