Car was running fine put it on my lift to check out the exhaust and let it down, went to back it out car cut off spins over but ill not fire, car has spark at the plugs and fuel to the check valve, one problem I saw is that someone before me installed a fusible link on the bottom front big red wire which goes to the ccrm. I kept playing with that fusible link and finnaly quit, came back one hour later pluged the 10 amp breaker back in car fired right up cut it off cranked it again went to go for a test drive and car cut will not start back. replaced the ignition moudule car will still not crank I had an extra ccrm I know it was good because had installed it to try and get the AC working so I had two working ccrms, possibly working with that fusible link unpluging and pluging back maybe this killed both of them. I pulled the intake and ohm'd the injectors all had 13.6 so I'm guessing there is not a problem there. So yesterday I took it to the garage to try and pull the codes if there were any and the snap-on scanner said cannot connect to the pcm?
so now i'm leaning towards a computer. Replaced the computer this morning and still spins over but will not fire, I was thinking maybe something need to be reset as the car now has a new computer? I took the intake hose off and sprayed gas down the throttle body the car fires right up and runs till the gas has evaporated. The crank sensor was replaced about 2 months ago and as I said it has spark so I don't think this is bad again. Please help me I'm about to pull my hair out? OL I forget I don't have hair
Thanks for any givin
Regards,
Brad
Regards,
Brad
