SDPATT,
It is my turn to appreciate the response. Thanks.
I was due for some "continuing education", and that "link" filled the bill.
Usually all you have to do is say the word chemistry and my eyes roll back, but there is no avoiding it. I'll have to grab the bull by the tail and face the situation!
The link article brings up the point about the negative affect of silicone products on the O-2 sensors and the catelytic converters.
Evedently if an RTV is used on an automobile, that is not made for automotive use, the silicone can effectively have a deteriorating affect on the O-2 sensors and the cats.
I get the impression that this is a long term "cause and affect", that is the cats and the O-2 sensors are not immediately "killed", but rather their useful life is dramatically shortened.
Is this caused by some sort of "off gassing" by the RTV after it is cured, or is all the damage done during the curing process?
Whether we understand all of the chemical interactions, or not, the important lesson to be learned by the "do-it-yourselfer" is; that silicone spray lubricants, and silicone RTV that is mot made for automotive use, should NEVER be used on or near an electronically controlled engine with cats.
Sulphur in gasoline:
I can tell when my wife has given in to her thrifty tendencies and purchased some "no-name- off brand" gasoline because of the sulphur "rotton egg" smell. She still does not understand why I get so angry about this.
Sulphur is a cheap substitute for better, more expensive, octane enhansers. So whats the big deal? Every time a piston comes up on a compression stroke a small amount of the fuel air mixture "blows by" the rings.
The sulphor will mix with the water condensed from the air and become sulphuric acid. The acid will eat into the engines bearing surfaces and bearings, as well as other parts.
The acid contributes to premature wear of the engine parts. The few pennies you saved on cheap gasoline will cost you dearly in the long run.
This is also why it is important to change oil regularly. The oil does not wear out, it gets dirty and contaminated.
All of the above is stated with simplicity, and not in the best "scientifically correct" terms. But, the gist of it is in congruity with the automotive literature. Food for thought.
Thanks again Scott, rangerj
