Car not running right
NHREDSHODRIVER
New Hampshire
I have a 92 MTX. I stopped driving the car for a few weeks I went to take it for one last ride before it got put away for winter I started the car up let it warm up started driving. Form a stop I started to accelerate normal not getting on it the car would just die right out but not stall then it would pick back up. I know the car needs O2 sensors. Any ideas?
Thanks Chris
NHREDSHODRIVER
New Hampshire
I was goin to use a Snap on Scan tool when i got home from school in a few weeks i was seeing if any one had any ideas on what it could be.
Thanks Chris
wood_e
The dude
Ames, IA
You don't even need that, it takes 5 minutes to do and we can probably narrow down your problem easier...
shofan33
Slick Silver
Edison, NJ
You said when it warms up right, Check it when it's from a cold start. If the problem doesn't occur it could be a sign of your crank position sensor going south for the winter ;) jk. But to be on the safe side check the codes in 2 weeks.
NHREDSHODRIVER
New Hampshire
yea i am going to check the codes throwing parts at the car is no way to fix anything. i will check into oil into the spark plug wells.
Thanks For the Help
Chris
