car is boggiing
SHOTIME#1
my 89 is bogging really bad I thought it was the plugs and wires so I changed them and it is still bogging just as bad. Also when you drive straught there is a really loud squealing noise but if you turn it goes away. I think the bogging might be the timing but how do you adjust it?
SHOTIME
Giver of life
Boston Ma.
Hey where did you come from? Thats MY name!
The Timing in not adjustable. Id check fuel pressure.
Are you getting any engine codes?
Squealing is probobally a wheel bearing. lift the car up off the ground with the tires on still. but your hands at 12 OClock and 6 Oclock and see if you can shimmy the tire. If you can you have suspension issues that need to be addressed.
SHOTIME#1
it was the fuel pump and the dust plate was bent and rubbing against the rotors. runs good now
crystizel
