Car Bogs Out At Wot-please Help???
SHOguy 92
Duluth, MN
I had my cam sensor go bad about 6 months ago. When it was most noticable the car would buck pretty hard under any throttle input.
Where in MN are you located? Mabey we can get together with some of the other MN guys and get it sorted out.
I'm with you there. My cars cam sensor went bad, it would idle 1l - 2.5k rpms and buck like crazy. I disconnected it and it runs decent, can't get on it at all under what I assume is 2k rpms, above thats fine.
I didn't read all of the original post, way too huge, but just pull the plug on your cam sensor and try driving it around. It should bog low like I said, but should be fine once your around 2k +. Also let it run for a few min the first time you try it without the cam sensor, the computer needs to get down what injectors and doing what and when.
**EDIT** nvm i see you got it fixed
