Car Battery
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
I was wondering what the specifications were on how many CCA's are needed for the 1994 MTX SHO.
I have heard around 900 is good but right now the battery that came with it has 415 CCA's, 500 CA's.
I noticed more and more lately (that its getting colder) that it will take a couple seconds for the engine to kick over sometimes...it will crank for a couple seconds, then start...I have heard this is due to the battery not having enough a** to kick it over.
I am also replacing the alternator...its going out and me needs more juice for louder music. thumbs_u
Any suggestions would be great. Thanks!
projectSHO89
SHOless In St L
Exceeding the manufacturer's recommended CCA is usually not needed since all you are doing is paying for capacity that you likely don't need.
A recent Consumer's Reports focused on car batteries and is very informative. Check out the periodical section of your local library and see if you can find it.
Steve
gosho89
Vancouver, WA
550 to 650 should be plenty in any climate
<small>[ December 17, 2002, 11:28 PM: Message edited by: gosho89 ]</small>
