can't find crank seal replacement
Larry Wittmer
Looked all through the post, and could not find a procedure on re[placing the front crank shaft seal, 95 auto trans: Larry
Larry Wittmer
Thanks' to all, Lot more of a undertaking the I thought. I was hoping maybe some belts and go in through the wheel well to pull the balancer. I had pulled and sealed the oil pan, thinking that was where the leak was coming from, and it was leaking up front. Now I am sure it's the front main. I also broke the back of the pan, because I missed a very well hidden bolt back by the fly wheel. I looked again and again, and still missed it.Thank goodness for my tig welder: Larry
itwonder
VA
Thanks' to all, Lot more of a undertaking the I thought. I was hoping maybe some belts and go in through the wheel well to pull the balancer. ...
That's basically what it takes; it's not so bad. Battery tray, wheel well liner, accessory belts, timing covers, loosen timing belt, pull the crank pulley, and you're in.
Devin
3.Slow
Pacific Northwest
