Twisted99
Cams seal change with timing belt on? Can this be acheived by removing the cam gears to change the seals behind them? I have the CID seal installed. It was the leaking one. However ...what must be done to change the two behind the cam gears. Is there a timing belt tensioner on the MTX? thanks
